13 sonuçtan 1 ile 13 arası
Konu: DTA S40pro
    tuncayakyz - ait Kullanıcı Resmi (Avatar)
    Kocaeli
    DTA S40pro
    Türkiye'de kullanılan bir ecu mudur? Tavsiye durumu nedir?
    ECU Functions
    Engine Configuration
    20,000 rpm capability
    Flexible and easily adapted to different OEM, crank, cam sensor arrangements.
    Genuine four and two stroke support.
    Twin injector engines.
    Semi - sequential injection.
    wasted spark or distributor.
    User controlled fan activation.
    Sensors can be calibrated individually with a lot of preset options supplied.
    Flexible Tacho Output
    soft and hard rev limits
    Main Fuel and Ignition Functions
    Comprehensive start up fuelling options both time and temperature dependant.
    Air, coolant and manifold pressure compensation maps.
    Throttle transient increase compensation.
    Throttle transient reduction compensation.
    RPM and load breakpoints can be calibrated by the user.
    Throttle or MAP as load.
    All maps with one or two dimensional with interpolation as required.
    Lambda control functions
    Extensive lambda parameters table to ensure stable closed loop operation and emissions requirements can be met where needed.
    Full three dimensional lambda target map.
    Auto-tuning function.
    Turbo Control Functions
    Open or closed loop turbo pressure control via PWM valve.
    Modify target turbo pressure by gear selected.
    Modify target turbo pressure by vehicle speed.
    Active base PWM map for easy calibration.
    Idle Control Functions
    Open or closed loop idle speed control via PWM valve.
    Closed loop idle target speed temperature dependant.
    Fuel enrichment table calibrated versus PWM percentage.
    Flexible Input/Output
    Three uncommitted input tables which use 0 5 volt inputs or any input the S60 knows already, linked to fuel and advance modifiers and a PWM output.
    Launch Control
    Fully flexible first gear launch capability.
    Extensively tunable to individual vehicles.
    Full Throttle Gear Shift Cut
    Shift cut capability with 1ms resolution, variable for each gear with
    full switch de-bounce capability.
    Voltage Compensation Tables
    User configurable voltage compensation tables for injector dead time
    and coil on time (dwell time).
    Diagnostics and Test Features.
    Full sensor diagnostics and fault recording.
    Extensive engine run time recording at different load and speed conditions.
    Ability to exercise injectors and coils without engine running for fault finding.
    Other Features
    Sealed Latching Connectors
    Size 115 x 100 x 41 mm
    Weight 268 gm
    All outputs protected against over temperature and over current
    Inputs protected against severe wiring mistakes and accidents
    Reverse battery protection
    Alternator load dump protection
    Input and Output Features
    Inputs
    Crank Shaft (Magnetic Only)
    Throttle Position
    Coolant Temperature
    Air Temperature
    Manifold / Barometric Pressure
    Lambda
    Oil Pressure
    Fuel Pressure
    Oil Temperature
    Battery Volts
    3 x User Defined Analogue (Shared Use)
    Launch Switch
    Shift Cut
    Undriven Wheel Speed
    Outputs
    2 x Coil Drivers
    2 x Injector Drivers
    Tacho
    Fuel Pump Relay
    Fan/Aux 2/Turbo Pressure Valve (Shared Use)
    Idle Valve (Shared Second Injector Driver)
    Shift Light
    evet türkiyede kullanılan bir ecudur benim 5-6 tane yapmışlığım var msky dada bunun farklısı kullanılıyor tavsiyemi istersen Kendi araban için Haltech sprint 500 kullanmanı tavsiye ederim
    Kocaeli
    Evet inceledim ebay'de var yaklaşık kdv içinde 1200$ gibi Türkiye'de...
    ney1200 gibi ?
    alperx - ait Kullanıcı Resmi (Avatar)
    Antalya - Polonya
    sprint 800 dolar civarı olması lazım
    Hayatta en hakiki mürşit ilimdir. - Mustafa Kemal ATATÜRK
    gurcell - ait Kullanıcı Resmi (Avatar)
    Jul 2007
    Papua Yeni Gine
    800 dolara tr teslim sprint 500 varsa bana 10 tane getirin hemen peşin alacağım.
    Uzaklaştırılmış Kullanıcı
    Sep 2008
    sprint500 bayi satış fiyatı 899 dolar , ebayda 999 dolar ve bunlara ek kargo , gumruk , vergi , komisyon vs vs hariç
    Antalya - Polonya
    turkiyede bayii olup olmadıgını bilmiyordum ama bilmiyorsam bu benim suçum degil, demek ki yeterince reklam yok.
    "800 doları civarı" dedim zaten 800 dolar demedim. ayrıca "olması lazım" dedim şu fiyata var demedim.
    854 dolara var ama harness yok. aklımda bu kalmış demek ki, ne var bunda ?
    bu ne agresiflik, biraz hoşgörülü olun
    Haltech Platinum Sprint 500 ECU ONLY | eBay
    Kocaeli
    ney1200 gibi ?
    Dta nın fiyatından bahsediyorum.
    Jul 2007
    Papua Yeni Gine
    854 dolara olanda harness yok ve shipping usa içi.
    Haltech'in sayfasında bile shipping hariç 1042 dolar.
    Bir fiyat söyleniyor, sonra herkes o fiyata inanıyor. Tepkimiz ona...
    Platinum Sprint 500 Autospec Flying Lead Kit Long - Platinum Sprint 500 - Universal ECU Kits
    1050 dolar a spint 500 e hayırlı olsun derim kapına göndertirim
    Antalya - Polonya
    fena fiyat degil
    tuncay olm beyin için harcadıgın paraya beyinle beraber Honda alırdın yahu.
    altın kural : herşeyin en iyisini al, o şekilde en ucuza gelir
    Kocaeli
    Alıntı alperx Nickli Üyeden Alıntı Mesajı göster
    doğru diyosun...
